Zetec into S1 install
Old Jun 21, 2007 | 06:47 AM
JesseT's Avatar
JesseT
Default Zetec into S1 install
Is there a lower water hose that would be a more or less straigth fit as the zetec water pump intlet is quite much bigger and a single one compared to the S1 Pump. Is the radiator outlet larger too in mk5/6 zetec Escort?
Old Jun 22, 2007 | 12:39 PM
SafeChav's Avatar
SafeChav
Pretty sure the outlet is a fair size bigger.
I run a Mk4 main hose on mine along with water pump and radiator, maybe a mk4 pipe and a reducer pipe will sort you out
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mondeomark
Sep 28, 2015 06:28 AM
