Valve stem clearance in bronze guide
Old Jun 21, 2007 | 04:17 AM
Souleyman's Avatar
Souleyman
Default Valve stem clearance in bronze guide
Hi, mates.
What can be the clearance of inlet and exhaust valve stems in bronze guides?
I saw in workshop manual the std clearance with std guides:
in - 0.03mm
ex - 0.055mm
It seems too large especially on exhaust valves. Isn't it?
And with the bronze guides the same clearances will be true or they can be some smaller?
Old Jun 21, 2007 | 05:49 AM
Exhaust has most likely got more clearance as they are hotter and expand more.
I would say the clearance is the same with BRONZE guides.
Old Jun 21, 2007 | 06:15 AM
Souleyman's Avatar
Souleyman
Thanx!
Old Dec 12, 2008 | 10:04 AM
Yura's Avatar
Yura
The original guides is not bronze??
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
