escort cosworth 1993 running problem
Old Jun 19, 2007 | 06:12 PM
ceri.demarco's Avatar
ceri.demarco
Default escort cosworth 1993 running problem
problem with power when you put your foot down 1/4 throttle the car seems to be running on a few plugs. on tick over its perfect rev it and it seems not to bad it only up when you are driving it on the road could it be an electical fault or a air gasket gone somewhere i,ve changed the spark plugs rotor arm & cap fuel pump & filter even changed the turbo nothing has worked please help
Old Jun 19, 2007 | 06:24 PM
dave green's Avatar
dave green
Have you still got the two large conectors by the power steering pump, they get wet and corrode they give all sorts of running problems. cut the conectors out and solder the wires together, takes a while but worth the trouble.
Dave
Old Jun 19, 2007 | 06:31 PM
ceri.demarco
thank,s i,ll try that
Old ford
Jul 31, 2015 06:50 AM
