T25 oil pickup/oil pump
Old Jun 19, 2007 | 06:06 PM
MTZ1's Avatar
MTZ1
Default T25 oil pickup/oil pump
I've changed my piston cooling setup to a Escort T25 style (I'm using BMW M3 1,3mm diameter jets)
now I'm not sure about the oil pump + pickup --> I could use the std. 4x4 pump + pickup and disable/close the stock spray bar ooor i could use the normal pinto pump (which would be verry reasonable) + don't know which pickup pipe...?!
any ideas for my oilpump/pickup?!
--> 500bhp+++
thx!
Old Mar 10, 2008 | 10:45 PM
SeppoJJ's Avatar
SeppoJJ
I've exactly the same problem (with the difference I've 1.9 Z3 jets). Does the 4x4 pickup pipe fit into pinto/T25 pump? And does that combination fit to standard 4x4 sump? And is that pinto/T25 pump as reliable as cossie 4x4 pump?
Old May 6, 2009 | 01:51 PM
- Sim -'s Avatar
- Sim -
same question from my side
any results?
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
