FRST motor
Old Jun 19, 2007 | 06:05 PM
steven botes's Avatar
steven botes
Default FRST motor
actually managed to buy an incomplete xr3 project down here fitted with a FRST motor!!!!!
only one i know of currently in SA , so it should be interesting.
tappet cover looks gunged up(replaced with another on the car) so i can only assume the motor is knackered?
havent actually lifted the tappet cover on it yet so i dont know for sure as i am still busy with my gotech drag car
a few questions:
injector size?
piston type?
max boost possible with the standard pistons?
is the fuel press reg same on it as the one currently fitted to my EFI CVH drag car?(i will be fitting a rising rate fuel press reg this weekend)
all help greatly appreciated
had some issues with my gotech , but the guys at gotech(about 15 minutes from my house!!!) are really helpful , dyno results to follow....
Old Jun 19, 2007 | 07:20 PM
NEWTON's Avatar
NEWTON
piston are MAHLE as standard,the pressure reg will be ajustible if you pull the cap off
bobsworth
77
Mar 24, 2016 09:30 PM
cossie362
Oct 11, 2015 03:53 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
marky_g
Sep 12, 2015 04:26 PM
dojj
Sep 8, 2015 08:31 AM
