t2 turbo
hey guys i got a hybrid t2 turbo on my car and the boost doesnt come on till late in the revs about 3.5 - 4000 revs.ive taken the turbo off and theres quite alot of play side to side but none in and out.theres also hairline cracks in the exhaust housing and theres very very slight chips on a couple of the exhaust proppellars(sp).any suggestions?cheers
In the inlet of the exhaust housing where it bolts to the manifold, there will be numbers.
They will be hard to read, and need a clean up to do so.
Its possible you have a much larger exhaust housing than required.
Or the actuator is suited to the turbo correctly.
carl
carl
JK12
33
Apr 26, 2021 12:09 PM
