When i push the button to clean windows there is no water coming out and no noise of the motor. I persume its the motor gone, anyone know how much to fix?
If it is the same pump for windows as sapphy, then they are pretty much the same across a lot of fords.
The headlight washer pump is also the same as a mondeo on a sapphy so would presumably be the same as escos one, and NEW for about Ł10 from HALFRAUDS, yep standard stock part, universal pump is the SAME.
if your car is an early BT model. there are 2 spare headlamp washer pump under the rear seat the exact same one - formally used for teh homologation water injection
