Cosworth Starting problem...
Old Jun 18, 2007 | 02:24 AM
2wd's Avatar
2wd
Default Cosworth Starting problem...
Hi...Just want ask if anybody had a idea for this...
Car wont start right away...It needs two "long" atempts before it starts...Also..I cant hear the pump prime when ign is turned on at first ..??
Please advice
Old Jun 18, 2007 | 06:46 AM
Does it run over FAST enough on the starter, when you first try or is it sluggish ?
To see if it is the lack of prime causing it you could temporarily just hook the pump up with direct supply and then see if it starts better.
Old Jun 18, 2007 | 08:27 PM
2wd's Avatar
2wd
Hi ...it sounds like it turn ok...so I will try to hook it up to the batt. direct and see if it starts ok after the pump has run.
So if that helps...any idea what to look for ??
Aug 14, 2015 07:29 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
