Leaking focus!
Old Jun 17, 2007 | 06:16 AM
jamie.patrick's Avatar
jamie.patrick
Default Leaking focus!
i have a leak in the passenger side foot well (ford focus 1.8 tdi), someone said its to do with a pollen tank or something like this, any idea what this is, i cant see where the leak is and it only gets damp when there is a very heavy downpour
Old Jun 17, 2007 | 06:26 AM
I don't know if this is the same on FOCUS, but on MK1/2 mondeos the pollen filter housing gasket leaks water as mine did.
Easy fix just take off the housing around the pollen under the scuttle/wiper area and reseal, I used LOCTITE 5910 has not leaked a drop since.
It only ever did it on the mondy on the passenger side front, when it was parked a certain way.
Old Jun 17, 2007 | 10:28 AM
THE RADMAN's Avatar
THE RADMAN
the pollen filter cover needs to be tucked under the metal part of the scuttle when refitted [this then acts like a gutter]otherwise water will run down below the plastic part and into car,check its been refitted properly
Old Jun 17, 2007 | 03:45 PM
ali24v4x4cosworthvan's Avatar
the plastic scuttle panel on the focus has to be bonded/ glued/ sealed (whatever you want) to the windscreen on the passengers side! if it isn't sealed water runs down behind it, into the pollen filter and onto your passengers feet! they were sealed with a double sided tape stuff from ford, which doesn't last!
Old Jun 17, 2007 | 04:26 PM
THE RADMAN's Avatar
THE RADMAN
it doesnt matter about that as long as its tucked in properly
Old Jun 17, 2007 | 04:29 PM
i fit windscreens during the week and when fitting a focus we're told to ask if the car has been serviced recently, because of that seal been broken! we then reseal them!
Old Jun 17, 2007 | 04:34 PM
THE RADMAN's Avatar
THE RADMAN
like you say they are orig stuck on with double sided tape but as long as the lower part is tucked under the scuttle then any water that runs down between the screen is carried away,if you dont get this fitted properly then it will pour in you can seal them also if you want but no need if its fitted properly in the first place
Old Jun 17, 2007 | 07:01 PM
Check the pollon filter seal my mams focus did the same so i changed the seal
krypton
Sep 23, 2015 07:29 PM
richierich1986
Sep 18, 2015 03:29 PM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
