is this an rs 500 intercooler(pics)
Old Jun 16, 2007 | 11:45 PM
////ANTHONY's Avatar
////ANTHONY
Default is this an rs 500 intercooler(pics)
and are they any good? and how much are they new? ill be fitting it under my radiator on my mk5 van thats fitted with an rs turbo engine thats running 1 bar boost
Old Jun 17, 2007 | 12:01 AM
cossie0_4's Avatar
cossie0_4
looks like a standard 2wd cossy intercooler to me
Old Jun 17, 2007 | 03:03 AM
TurboShed's Avatar
TurboShed
Cossiemodo
An RS500 or RS500 style intercooler is massive, bigger than your radiator, you'd know if you had an RS500 cooler - and the one in the pic certainly ain't one!
Old Jun 17, 2007 | 05:04 AM
As said standard 2wd intercooler.
The RS500 type is easy to identify as said it is BIGGER than the main rad, and bolts onto the chassis rails just like the main rad does, in front of it, then the two inlet outlet pipes point out above the main rad, and are about 8/9" long.
Old Jun 17, 2007 | 08:29 AM
////ANTHONY
thanks guys, it was in the back of an old van i braught, theres also some 4 pot calipers and discs, i have no idear if they will fit my mk 5 van yet
Old Jun 17, 2007 | 10:56 AM
costina's Avatar
costina
Live long and prosper!!
That cooler would be fine for 1 bar of boost any more than that i would recommend the 4x4 cos version,these can be identified bt havin a straight dump valve take off...
As for the brakes it can be done with some brackets to suit
Old Jun 17, 2007 | 12:29 PM
Might as well use the calipers as so much better than std single piston ones.
Old Jun 17, 2007 | 10:18 PM
////ANTHONY
yes i think i will use them, ill proble have to make a brackets to make them fit, unles someone like burton or someone makes them
Old Jun 18, 2007 | 06:37 AM
Offer them up with 4x4 cossie discs 273mmx24mm, and I think you will find they go straight on, just need to tap the lug hole, which conveniently is already the right size!!
JK12
33
Apr 26, 2021 12:09 PM
Ridgey
12
Nov 2, 2015 06:54 PM
155lee
Oct 27, 2015 04:55 AM
simonmcf
Sep 22, 2015 08:40 AM
3doorcozmess
Sep 20, 2015 06:15 PM
