4x4 Cossie Suspension
Old Sep 22, 2004 | 09:41 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Default 4x4 Cossie Suspension
Will XR4i 4x4 springs and shocks fit a cossie 4x4 ? are they the same and will they fit ?
Old Sep 22, 2004 | 09:55 PM
Jim Galbally's Avatar
Jim Galbally
rears are the same so theyll deffo fit 100%
as for fronts... there is no such thing as an XR4i 4x4
theres either XR4i or there's XR4x4
XR4i WILL NOT fit at the front
XR4x4 will fit at the front...
the parts are identical mounting wise, but standard ford stuff has different finis as the springs and dampers have different rates n stuff on there... itll all fit fine and work fine just might be a bit high n stif
if we talking aftermarket, they'll be identical as all same part numbers
turbotrev
14
Sep 27, 2015 10:44 AM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
