Long studded how many times can they be re used ????
Jun 16, 2007 | 04:22 PM
I have 6 long Studed conv and it looks like the head might have to come off (poss head gasket gone)
I aready re-used them once before is it safe to use them again without replaceing them ???
Jun 16, 2007 | 05:56 PM
Jun 16, 2007 | 06:22 PM
you can keep reusing them as they are not stretch bolts. ( the 6 long studs that is ) however you will have to replace the 4 standard bolts.
Jun 16, 2007 | 06:57 PM
Cheers mate i thought it would be ok just needed to check
Jun 16, 2007 | 08:01 PM
which ones do you put the long studs in? middle six?
just out of interest
Jun 16, 2007 | 08:37 PM
how can you do another headgasket when your runing no boost
Jun 16, 2007 | 10:54 PM
yes. unless you go for the 10 long stud conversion.
Jun 17, 2007 | 02:18 PM
check the threads on the nuts before you put them back in though,i had to renew mine
mountune kit
James Porter
Oct 28, 2015 12:17 PM
Toe Knee
Aug 23, 2015 08:31 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Billy_RS
Aug 3, 2015 08:43 PM
lockie
Jul 31, 2015 10:03 PM
