RS 500 manifold
Old Jun 15, 2007 | 06:05 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Default RS 500 manifold
Hi,
I need a question answering please
On a rs 500 inlet manifold does anybody know if the inlet runners have got dowels to locate them on the head?
I've got a set of inlet runners for sale on ebay as I don't need/want them and I've been told the std 500 ones have got dowels on them as std.
Old Jun 15, 2007 | 07:12 PM
Dan@Rapid-Ford
anybody know??
do they have dowels or not?
Old Jun 15, 2007 | 07:23 PM
Ryan's Avatar
Ryan
yes 500 trumpers have locating dowels.
Old Jun 15, 2007 | 07:25 PM
Dan@Rapid-Ford
cheers ryan,
have you seen them with your own eyes? as I've spoken to 2 people with 500 manifolds and they don't have them and the one I have doesn't have them either
Old Jun 15, 2007 | 07:27 PM
Only seen one RS500 one and that did NOT have them either.
Old Jun 15, 2007 | 07:33 PM
Dan@Rapid-Ford
I've not seen them either - why would the manifold be doweled to the head if it's not port matched
I've seen aftermarket O-ringed done on std manifolds and I can understand doweling if the heads ported but std?
the std gasket wouldn't fit and I've never seen a 500 inlet gasket marked up differently
Old Jun 15, 2007 | 08:00 PM
Tony Ryan's Avatar
Tony Ryan
Its not for sealing purposes, its done because of the vibrations on a solid mounted engine shaking the manifolds loose , and yes, ive seen loads of dowelled manifolds and the last std RS 500 engine i had in had dowels in the manifold on ports 1 & 4 !
Old Jun 15, 2007 | 08:03 PM
PAUL S's Avatar
PAUL S
I have a 500 one in my shed and it has holes in it to locate the dowels - also the throats closest to the head are machined out slightly for about the first 10mm
Old Jun 15, 2007 | 08:17 PM
Dan@Rapid-Ford
cheers for the info
I'll edit my advert later - so its a case of some have, some haven't but they should have the holes for the dowels?
strange though I'll have to go and see my friends one to have a lookie if it's got the holes but he's not noticed.
Old Jun 15, 2007 | 08:29 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
110% Rs500 does have dowels...
Old Jun 15, 2007 | 08:37 PM
Dan@Rapid-Ford
cheers for that
by any chance does anybody have any pictures - I've gotta now show the people who said that theirs haven't got them that they should have them
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
