Frequency Generation?
Old Jun 15, 2007 | 10:00 AM
JohnP001's Avatar
JohnP001
Default Frequency Generation?
Does anyone know where I can get hold of some software for frequency generation? I want to create a frequency of around 50 hz, but have the ability to change the phase as well. Needs to be free
Thanks
John
Old Jun 15, 2007 | 10:11 AM
GARETH T's Avatar
GARETH T
what you trying to drive?
Old Jun 15, 2007 | 11:20 AM
st_owner100's Avatar
st_owner100
Lots of pc based signal analysers such as SignalCalc have built in signal generators. But that's a bit of overkill if you dont' want to analyse the data.
A quick google search of 'online signal generator' came up with loads of hits. inlcuding this, which should work nicely.
http://www.natch.co.uk/downloads/SigJenny/SigJenny.html
Old Jun 15, 2007 | 12:04 PM
Graham S1's Avatar
Graham S1
cool bit of software.
Always wanted to try the 33hz experiment.
Old Jun 15, 2007 | 01:08 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Fantastic program - stick it on 60 Hz, wind the sub up and watch the house windows shake
Old Jun 15, 2007 | 05:00 PM
JohnP001's Avatar
JohnP001
When I was at school, which was a long long time ago, I was taught (if I remember correctly) that you could cancel a wave by emitting a wave directly at the source of the same frequency but out of phase. Therefore I’m trying an experiment to see if this works.
Here’s the problem.
The next-door neighbour has installed a hot tub. The hot tub emits a low frequency hum, which I assume is around the 50hz range, but I need to measure it. It’s not loud, but I can hear it all though the house. It’s one of those penetrating sounds.
Here’s the solution.
If I emit the same frequency at the hot tub through a sub woofer, but out of phase, I should cancel the noise.
John
Old Jun 15, 2007 | 05:02 PM
JohnP001's Avatar
JohnP001
Thanks for the link. Will have a go this weeekend.
John
Old Jun 15, 2007 | 05:06 PM
rssteve's Avatar
rssteve
will it not cancel the hot tub but make you here your sub?
Old Jun 15, 2007 | 05:12 PM
nilrem's Avatar
nilrem
STOP!... Carry on
theoretically, it could work... but it would have to be 180 degrees out of phase... and ideally emmiting from the same spot form the hot tub...
might be worth trying it though if its all free!
Old Jun 15, 2007 | 05:13 PM
JohnP001's Avatar
JohnP001
Well, I don’t know. I’m going to put the sub down the bottom of the garden pointing in the direction of the neighbours.
Old Jun 15, 2007 | 05:16 PM
JohnP001's Avatar
JohnP001
As it’s for free, it’s worth having a go. If anything, I can piss the neighbours off with a noise of my own.
Old Jun 15, 2007 | 05:18 PM
nilrem's Avatar
nilrem
STOP!... Carry on
lol!!! whats the 33hz one? is that the supposed "brown sound"??
Old Jun 15, 2007 | 05:37 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Supposed to make women orgasm in seconds
Old Jun 15, 2007 | 06:06 PM
nilrem's Avatar
nilrem
STOP!... Carry on
oh right! cool!! i know you can download something off the FUEL website (the ones that do the car audio) that can change the frequency of your sub!
Old Jun 15, 2007 | 06:59 PM
the original's Avatar
the original
you won't cancel the hot tub sound that way, you may be able to create local spots where it is quieter but move away a few inches and you will add the waves together and make it even louder
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
Toe Knee
13
Jan 22, 2005 06:23 AM
cozzie4d
Dec 29, 2004 11:01 AM
Bobby Singh
Jul 1, 2004 12:13 AM
