General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
to go up to light blue injectors on my 2wd sapp?running dark greens at the mo standard fuel pump,standard clutch(i know this will have to be changed but to wot,dont want a horrible clutch!)205 block lower compression but not sure to wot,L6 ecu,coopers 0 ring headgasket,ported,flowed head,reprofiled cams to fast road spec T34 turbo .48 exhaust,pace RS500 intercooler,magecor ht leads,group A coil do u think i will need different cams etc???
Just a chip change isn't it ?
What power do you get at the mo if you don't mind a nosey git asking as I am doing a very similar spec to yours at the moment.
