4x4 wobble
Old Jun 14, 2007 | 10:07 AM
Smoker's Avatar
Smoker
Default 4x4 wobble
seem to have a problem with my 4x4,when i accelerate hard the engine vibrates like mad,im also geting a clonk sound from both front wheels and when cornering left the o/s wheel feels like its going to fall off,the tyre also cathes the arch. i have changed the 2 engine mounts to collins items but still not solved the problem,its fully poly bushed so dont think it could be any bushes? well any one that can point me in the right direction,will be much appreciated, once again many thanks for looking
Old Jun 14, 2007 | 05:39 PM
TurboShed's Avatar
TurboShed
Cossiemodo
What wheel and tyre sizes have you got fitted?
Old Jun 14, 2007 | 06:05 PM
cossiechuckie's Avatar
cossiechuckie
had the same sort of problem on mine a while back and it was the driveshaft. The inner joint bearings had started to break up, new driveshaft and it was good as new
Old Jun 14, 2007 | 09:07 PM
cameron2's Avatar
cameron2
Mine did this and it was a fucked hub. The wheel bearing collapsed due to the hub being very worn.
Old Jun 15, 2007 | 11:57 AM
Smoker's Avatar
Smoker
Default 4x4
i have esc cossy wheels on 215/45/16 tyres,its had a new shaft put in and a new hub
Old Jun 15, 2007 | 03:51 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Balljoints ok??
Old Jun 15, 2007 | 06:48 PM
saff cosworth's Avatar
saff cosworth
try changing the wheels around. see if that works
Old Jun 16, 2007 | 08:33 AM
Smoker's Avatar
Smoker
_________________
experienced that just before this problem
Old Jun 20, 2007 | 02:42 PM
Smoker's Avatar
Smoker
Default sorted!
it was a wonky driveshaft,bent it up after my wheel bearing collapsed and then i tried to drive it. now sorted so thanks guys n girls
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
