rear shocks
Old Jun 14, 2007 | 07:44 AM
saph in dorset's Avatar
saph in dorset
Default rear shocks
Hi
i have just bought a pair of bilstein rear shocks and having read the haynes manual it says to undo the current ones with the car on the ground. would it matter if i did it on axel stands as i cannot get under the car when on the ground.
thanks
Old Jun 14, 2007 | 07:54 AM
No it would be perfectly ok, the thiung the manual is trying to say but does not is the wheel wil drop a bit so just put a trolley jack etc under each one in turn, under the flat section of each arm in turn, to take a little bit of the weight before you undo shocks.
Old Jun 14, 2007 | 10:11 AM
saph in dorset
thanks tabetha great to have you back.
thanks for that. i thought it would be ok but just wanted to check first. it makes sense that the wheel would drop a bit but would not of thought about it.
thanks again
Old Jun 14, 2007 | 11:08 AM
It hurts if it drops on your bits!!
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
The Enigma
Sep 12, 2015 10:12 PM
Topjoe9
Sep 12, 2015 09:50 AM
cossirob
Sep 3, 2015 09:17 PM
