MK II fiesta
Old Jun 13, 2007 | 06:58 AM
Maki's Avatar
Maki
Default MK II fiesta
Hi I don't know much about fiestas, so maybe you can help.
Were MKII fiestas fitted with CVH engines? I wonder is it lighter then MKIII/IV escort? and would the RST engine fit without any modifications?
Old Jun 13, 2007 | 05:58 PM
Phil DJ's Avatar
Phil DJ
I know the MK2 XR2 was fitted with a CVH. It's much lighter than an escort and the engine will fit in with a few modifications.
The engine itself should go straight in but you will have to do mods for intercooler, etc.
Old Jun 13, 2007 | 07:06 PM
Brookesy's Avatar
Brookesy
rst engine will go in but you need to cut a piece out the front x-member to clear the downpipe, wiring loom needs the esrt engine loom splicing into it, you need a swirl pot for the fuel tank.
Old Jun 13, 2007 | 09:36 PM
XR2's Avatar
XR2
Looks like there are people all over the world that like the MK2
Old Jun 14, 2007 | 06:18 AM
Maki's Avatar
Maki
It's not that I like it ... I'm hunting for lighter body to compete in drag races.
My escort after all I did to it weighs somewhere in the region of 800 kilos.
What is the weight of MK2 fiesta? Maybe MK3 has the same weight too?
Old Jun 14, 2007 | 03:30 PM
XR2's Avatar
XR2
MK3 Fiesta has nearly got the same weight as the MK4 Escort. My XR2 is weighting at 840 kg according to papers
Old Jun 15, 2007 | 05:13 AM
Maki's Avatar
Maki
My escort in papers is 970 kg, so maybe it's worth swaping?
P.S. Eine coole seite du hast da und deine fieste siet fantastisch aus
Old Jun 15, 2007 | 05:33 AM
XR2's Avatar
XR2
When you just want to do Qartermile runs then the MK2 might be the better choice.
Thanks!
Old Jun 15, 2007 | 05:39 AM
Maki's Avatar
Maki
I wonder now what driveshafts people use as they swap those engines? RST ones (do they fit), or standard fiesta ones?
Found one XR2 down here for reasonable price, so can't sleep now
Old Jun 15, 2007 | 11:11 AM
XR2's Avatar
XR2
Standard Fiesta XR2 or Diesel ones
Old Jun 15, 2007 | 11:29 AM
Maki's Avatar
Maki
XR2?
Old Jun 15, 2007 | 11:41 AM
XR2's Avatar
XR2
XR2 and diesel driveshafts were thicker than the standard ones on the MK2. Buy that XR2, it's also got the engine lowering and the bigger brakes.
Old Jun 15, 2007 | 01:05 PM
Maki's Avatar
Maki
By the way, would fiesta take my RST front suspension with all the driveshafts and brakes as I have bigger ones fitted to my RST?
Old Jun 15, 2007 | 03:58 PM
XR2's Avatar
XR2
No. You can just fit the springs to the Fiesta and there's a way to make the RST brakes fit.
Old Jun 18, 2007 | 10:36 AM
Maki's Avatar
Maki
They sold that XR2 I was hoping to buy
Old Jun 18, 2007 | 09:46 PM
XR2's Avatar
XR2
I hope you'll find another one. They're rare these days unless you live in the UK and want one with the steering wheel on the wrong side
Old Jun 19, 2007 | 05:14 AM
Maki's Avatar
Maki
There is one dead MKII with non XR2 with some small engine... does it have any major difference? You mentioned brakes and suspension...what is different in suspension?
Old Jun 19, 2007 | 05:42 AM
XR2's Avatar
XR2
Shocks, springs, front hubs, anti roll bar and strut braces
Old Jun 19, 2007 | 06:32 AM
Maki's Avatar
Maki
But I guess they would be just as good for dragracing as XR2 ones?
Old Jun 19, 2007 | 03:28 PM
XR2's Avatar
XR2
errr... maybe. You just want to do straigth runs?
But it's worth to fit better Brakes than the 1.1's
Old Jun 20, 2007 | 05:12 AM
Maki's Avatar
Maki
I'm thinking about my escort brakes as they are 278 mm. You lold me it's possible to fit. I think I would do just that
Old Jun 20, 2007 | 09:00 PM
XR2's Avatar
XR2
maybe you might check out www.xrtwo.com
You can find many hints on this forum how to upgrade MK2 brakes and engine!
Old Jun 21, 2007 | 05:22 AM
Maki's Avatar
Maki
I even registred to it, but as I try to log in everything puts on hold and nothing happens Some fucking firewall or something here at work
Old Oct 18, 2007 | 09:07 AM
Maki's Avatar
Maki
found this site...
http://www.retrofiesta.co.uk/
there is in information section turbo power guide... Please someone tell me what is true and what is not about fiiting the ERST engine into MK2... I think it's more about MK1, so not sure what do I have to look at. For example do I have to make any cutting to the wing for the ERTS gerbox? are'nt MK2 XR2 gearbox cases the same as escort ones? then why there is a need to cut anything?
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
