Cosworth over fueling
Old Jun 9, 2007 | 05:10 PM
sideways saff's Avatar
sideways saff
Default Cosworth over fueling
i have a 1990 2wd cossie,several weeks ago the bottom end decided to knock badly,so stripped the engine out and found it was knackered,i have borrower a mates spare engine and put all my exhaust manifold,sensors etc on it,but it is massivly over fueling and wont start,if i pull the injector leads off i can get it to fire and get the leads back on i can get it to run,but it kicks out black soot (over fueling) ? and when i turn it off it wont fire again,i have tried a new map sensor and also put my stage 3 chip,3 bar and greens in to eliminate any of those and it still doesn't work,the only thing that was on the engine when i got it was the inlet manifold could this be leaking any air ? p.s all sensors were working fine on my engine till it died,any thoughts welcome as i am meant to be taking this to lemans on wednesday night.........
thanks in advance
Old Jun 9, 2007 | 05:13 PM
rapidcossie's Avatar
rapidcossie
Coolant temp sensor?
Old Jun 9, 2007 | 05:17 PM
sideways saff
it was working ok when it came out of my last engine ? but always worth a try !
Old Jun 9, 2007 | 05:18 PM
rapidcossie
its the cheapest sensor and your car is displaying all the sypmtoms
Old Jun 9, 2007 | 06:21 PM
costina's Avatar
costina
Live long and prosper!!
As above
If your inlet was leaking it would have a high idle speed and run leaner
Good luck and watch out for my two mates and there mits evo's a red tommi and a silver one all logo'd up
Old Jun 9, 2007 | 06:34 PM
sideways saff
you have just made me a HAPPY MAN,i was sure the sensor was ok so checked the wiring plug and one of the wires had come away from the terminal all fixed now and running ........THANK YOU THANK YOU .all i need to do now is oil change,top up with anti freeze,and fit a few minor bits then i can get it stickered up,and fit my dixie horns thank you again.
COSTINA
i'll keep my eye open for the mits evo's,but will be keeping my speed down as it's not my engine and need to give it back once mine is built,but then again as it's not my engine i think i might have a go
Old Jun 9, 2007 | 07:06 PM
rapidcossie
Always check the easiet things first mate
SmudgerByName
52
Jul 28, 2016 06:14 PM
Russ Hill
Aug 31, 2015 06:44 PM
jc1989rs
Aug 30, 2015 06:32 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
