Valve stem oil seals
take the valves and springs out, then squeeze them with needle nose pliers, but squeese all round till they loosen, then just pull them but dont be to violent!!!!!
eay job once you done 1 or 2 of them you will find it easy.
to remove them if theyre very hard sometimes you have to split them down the side, being very careful not to damage the valve guides.
refitting them i normally use a 12 point socket and a bit of wd40 to push them onto the valve guide
never had any problems doing it this way
Right im not having a good time with these oil seals im on my second set now the i have been oiling them and taping them on with a 12 mm socket and even bought a valve stem installer but the rubber keeps stripping out from the inside ive only managed to get a couple on without damaging the rubber any advice would be super
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
