Block Swap HELP !!
Old Jan 12, 2004 | 09:14 PM
Default Block Swap HELP !!
I am in the middle of collectig parts to swp my tyred 205 block to a 200 item.
I understand i will be able to use the crank from my 2wd block
Is everything else transferable or do i need a 4x4 water pump etc
The 200 block i have is bare ( waiting for my pistons to arrive)
Would it make any difference if i use a 4x4 head ???
Any help would be great
Thanks
Old Jan 13, 2004 | 05:45 PM
RobS's Avatar
RobS
dont need water pump or thermostat housing they,ll swop. as
long as u got complete 2wd engine and acc u'll be ok, think the
crank ok 2, 4x4 head is better
Old Jan 13, 2004 | 06:41 PM
Yes i have started with a complete 2WD engine.
Does this mean all the little bits and bobs will transfer straight over
Do i have to use 4x4 water pump & thermostat housing if using 4x4 head?
Old Jan 13, 2004 | 07:21 PM
Toe Knee's Avatar
Toe Knee
Nah u don't, but supposedly the 4x4 stat housing and pump is more efficient but dont quote me on that.
Old Jan 13, 2004 | 11:18 PM
velocity's Avatar
velocity
make sure the 200 block comes with its own crank main bearing caps,as these are matched to there own block by machining and there position is numbered
Old Jan 14, 2004 | 02:53 PM
yep what they all said!
swaped my 205 bits into a 200 block and all fits straight in mate!
Old Jan 14, 2004 | 08:26 PM
Default Block swap
Yes my block came with the end caps !!
So if i want 4x4 water pump and thermostat housing i wont need 4x4 radiator or anything like that !!
Thanks for all help !!
Old Jan 15, 2004 | 02:49 PM
RobS's Avatar
RobS
think u ok with rad m8 but some hoses are different
Old Jan 15, 2004 | 07:51 PM
Default block swap
Should be interesting when ordering my samcos
Old Jan 15, 2004 | 09:25 PM
RobS's Avatar
RobS
well if u use 2wd water pump and thermostat u ok, but 4x4 are different
hoses, and theres 1 between pump and housing which samco dont do
Old Jan 16, 2004 | 08:47 PM
Thanks mate i will keep this in mind
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
