rear beam
is a rear beam out of a 4wd escort cossy weaker than a 2wd beam as iam going to do the rwd conversion on my escort and just whant to no weather i have to change the rear end iam going for big bhp so strogest will be best so could some one give a bit of advise thank youuuuu
Spiky, yes its up for sale but now thinking off keeping it and making it rwd unless the price is right and i will let it go .......so as for the beam i was told to use a 2wd one because its stronger is that true iam puting big hp throught and a 9inch rear diff
trailing arms are identical - driveshaft cups and shafts are the only difference
the beam where the diff mounts is different.
HTH
Daniel.
HTH
Daniel.
pm what you would like dude
Rich
a 9" diff wont fit in a 4x4 rear beam!
just use a 2wd saff one and double skin it.plus weld triangles on the swing arm pick up points.that will be strong enough.
or idealy put a square beam in.
oh thank you some one aswerd my question ....3would any one be intrested in al my 4+4 bits as i need all the 2wd bits so if any one whants to do a swap with all the bits then get in toch if not then its up for sale .........conversion will be done in 2 weeks from now thank you all
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
