You will never guess it
Old Sep 21, 2004 | 09:43 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Default You will never guess it
Now the story starts with my esccos...
I have had some serius problems with the car in about 2 months, with the engine management...
Whwn i rev it up to about 3-4000rpm, it shuts down with a REALY LOUD BANG, and i have to re-start it again.... it does this under load, under light load and with or without boost...
Now my gues was for starters : the mapsensor... i changed that one... error still there...
Secondly, the blue or brown sensor( because it`s pretty heavy to start when the engine is cold) changed them too... error still there...
Changed the leads, coil, plugs, etc etc.... error still there...
Talked to woodford, bought an new P8 boks on E-BAY... got it to day.... error still there....
WTF!?!?!?!?
Then suddently i thougt---my car is fitted with an 2wd-manifold and turbodamper from baily, and the exhaust is ratteling a little bit when i rev the engine, could it be????
OH YES, i turned the baily damper 1/2 a turn, then it got tight, drove a nice long trip, and the foult was gone... SOMEBODDY SLAP ME!!!!!!
So remember folks.... ALWAYS check if your damper sits tight...
THIS TOOK ME FOOOOOOKING 2 MONTS TO FIND OUT
Old Sep 22, 2004 | 07:53 AM
Rene's Avatar
Rene
hey at least u got it sorted now
Old Sep 22, 2004 | 07:55 AM
Spiky's Avatar
Spiky
how would the damper solve that?????
your exhaust manifold must be loose then?????
Old Sep 22, 2004 | 01:39 PM
cossiemanden
No not realy, but because og the damper was loose, the manifold and exhaust-system began to vibrate at different rpm, and this vibration went throu the top/block and down in the nocksensor...
When this happens the chip shuts down, because off the retard off the ignition...
Butm wtf, it WORKS now... hehe
Old Sep 22, 2004 | 01:42 PM
Spiky's Avatar
Spiky
didn't realise the cossie had a knock sensor
glad it's working again dude
R4N SS's Avatar
R4N SS
glad u got it sorted.
Old Sep 22, 2004 | 01:52 PM
St3V3_C's Avatar
St3V3_C
The later stuff has mate
And yea, bitch of a fault.
Daniel Howard
17
Sep 26, 2015 12:39 AM
krypton
Sep 23, 2015 07:29 PM
Quaver
Ford Focus Range
Sep 18, 2015 09:23 AM
The Enigma
Sep 12, 2015 10:12 PM
Ben26
Sep 3, 2015 07:55 PM
