What would cause a rad to split?
Old Sep 21, 2004 | 07:15 PM
RSrussell's Avatar
RSrussell
Default What would cause a rad to split?
Bit of a strange one this morning, came home an water was pissing out of my runabout.
After an hour & half of removing the lights, front panel etcetc to get the rad out, it appear to have a split in one of the bottom cores. Not probs, i'll stick some radweld in there.
Then it started to overheat, the fans wouldn't kick in and the heaters were only blowing out cold and the rad kept pissing water out.
Removed it all again, thermostat is good (but bought a new one incase) , bridged the fans, they work (a new fan switch needed i guess) and bought a new rad.
But before i fit them, i wanna make sure this rad doesn't split again, so what could have caused it?
Does this sound like a fooked water pump problem
Thanks
Old Sep 21, 2004 | 07:17 PM
MadMac's Avatar
MadMac
Not tnough antifreze would make the rad corrode from the inside out.
Old Sep 21, 2004 | 07:36 PM
Matt @ CAE's Avatar
Matt @ CAE
Old Sep 21, 2004 | 07:38 PM
whitneyd's Avatar
whitneyd
To much pressure from ????? you guessed it a fooked head gasket. Good job Matt
Old Sep 21, 2004 | 08:10 PM
RSrussell's Avatar
RSrussell
Headgasket, it can't be that, as i hasn't lot any power (well it hardly has any ), theres no mayo in the oil, doesn't/didn't lose any water (very little top up every month)
Old Sep 21, 2004 | 08:53 PM
dave green's Avatar
dave green
It could still be head gasket ,
Old Sep 21, 2004 | 10:30 PM
Uncle Henry's Avatar
Uncle Henry
agreed, either head gasket or just plain old wear and tear!
I can't believe you honestly expected radweld to cure it though
Old Sep 21, 2004 | 10:35 PM
Phil's Avatar
Phil
Jeebus
I had the same with an old 306 once. was fine for years then overnight just lost all the water out the rad! New rad fixed the problem.. none of these cossie-paranoia headgasket worriers
Old Sep 21, 2004 | 10:36 PM
DazC's Avatar
DazC
Fucked headgasket
Or wear and tear....or just your car is shit.
Old Sep 21, 2004 | 10:54 PM
hybrid t3's Avatar
hybrid t3
probably wear and tear. pressure would probably blow a hose off first. Always look on the bright side
Old Sep 22, 2004 | 09:24 AM
RSrussell's Avatar
RSrussell
Yeah daz it is shit french shit to be precise
So what is rad weld any good for then? repairing a leaking rad
Old Sep 22, 2004 | 09:27 AM
Martyn's Avatar
Martyn
I had a fooked head gasket that didnt show any mayo for well over 2 months before it finally gave up
Old Sep 22, 2004 | 09:28 AM
AlexD's Avatar
AlexD
Post Miester !
I found that if yer head gasket goes, the bottom of the rad can also bow aswell..
Al...
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
pabloXR
Sep 21, 2015 12:42 PM
Ben26
Sep 3, 2015 07:55 PM
