WHAT POWER WILL THIS TAKE (wire rung block) HELP PLEASE
just stripped my engine down to find it is fitted with group a head gasket and the bloc is wire rung just how reliable is this set up and can it take much boost pressure
it will be fine m8 wire rining a block is old way of doing things but it does the job i had done a engine for a customer not long ago the car runs 2.5 bar on std comp and hasnt blown up yet
IF its been done correctly (.6mm deep groove and 1mm welding wire) it will be good.
Make sure your head gasket lines up with the rings perfectly though as some head gaskets seem to be slightly out of line.
Lee
Lee
Originally Posted by garyrs
am i looseing the plot or did you make a post the other day about your block being cracked??? could be me
Originally Posted by PGT
had nowt but bother with mine. finished up shaving 0.75mm off block face and going cometic
You running a 2mm gasket now then?
TPM961
Jan 15, 2018 10:50 AM
