Management Question
Old Jun 5, 2007 | 02:26 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Management Question
On a Mini , they have 5 port Non-cross flow heads, So the Spi (Single point Injection) Mini's only run 2 Injectors one for each inlet port.
If you was converting it to Turbo Efi instead of using the Metro Turbo Carb set-up
And you wanted an Aftermarket management, Can you run the management to run 2 injectors? Or does it have to be four, Like a normal turbo 4 cyl / 4 inj car?
Thanks
Old Jun 6, 2007 | 01:59 PM
Charlie Chalk
Unknown.
Anyone...
Old Jun 6, 2007 | 02:18 PM
sailorbob's Avatar
sailorbob
It depends on the management but most you can configure pretty much how you need it. Even if your chosen management won't let you only use two injectors you could always plumb all four in
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
deathrider666
Sep 28, 2015 06:12 PM
