radiator
Old Jun 4, 2007 | 06:34 PM
sigo19's Avatar
sigo19
Default radiator
hi i was wondering i have a ford puma 1.7 16v and i know this is the same engine that goes into a fiesta i was wondering could some one please give me a detailed explanation of how to bleed the radiator please because i believe i have a pocket of air trapped in there, because the car overheats on a regular basis and when i check the radiator the top is warm and once i get about half way down it it turns ice cold.
cheers si
Old Jun 19, 2007 | 11:12 PM
phill295's Avatar
phill295
remove the colant and start again then replace colant in to bottle and run car then top up to max level let the car run until the fan cuts in the check that thermostat has opened all hose should be hot now check colant level then replace cap and done
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
