bad misfire help please
Old Jun 4, 2007 | 05:29 PM
andyuk's Avatar
andyuk
Default bad misfire help please
drivin around in my 2wd cos and missed a gear and went in to first by accident,it reved like a bitch now the car mis fires on cylinder 3, i checked the cams and injectors and timing, replaced the dizzy rota arm,spark plugs tryed the leads what could this be anyone, thanks
Old Jun 4, 2007 | 05:32 PM
Alvyn's Avatar
Alvyn
could of bent a valve or two possibly, get a compression test done and go from there!
Old Jun 6, 2007 | 07:56 PM
andyuk's Avatar
andyuk
Default comp
did a compression test 1 had 150psi 2 had 150psi 3 had nothink 4 had 50psi valves dont look bent, or can i not tell if bent till i take them out
Old Jun 7, 2007 | 12:14 AM
BigErn's Avatar
BigErn
Bent valves in 3. Head off and strip down time.
Old Jun 7, 2007 | 06:59 PM
Alvyn's Avatar
Alvyn
Default Re: comp
from the signs I'D say the valves have clipped hard on the piston in number 3 and they are NOT seating properly so head off for further inspection
Fordmad!
Sep 29, 2015 07:03 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
