Replacing Escort rear windows
that is correct Sim... Is it totally stripped??
I read somewhere resently that Escort 3dr rears fit straight over without needing anything .. beside the window and seal ofcause.
Originally Posted by the youth
the caps are pennies from ford just change them I did mine 4 years ago and there still fine now
Steve
Steve
Thanks
yes everything taken out, all damping material and so on as well.
yes the normal 3 rd escort rear windows will fit, as well as the complete doors.
I m thinking to get polycarbonate rear windows.
not really through as i m looking for a possible supplier and prices.
paint the bolts with a spray primer, that will stop them rusting, and put a little bit of sealant/ jointing compound on the back, the non hard setting stuff, that will A) stop the bolts rusting, and B) stop water getting in and causing corrosion, which then stops rusty water running down your window
Thanks
jessie_rs
11
Jun 3, 2019 04:57 PM
