Uprated High Flow water pumps
Does anyone know if you can get an uprated water pump for a CVH?
Or should i go for an electric one?
Problemi have is there is not enough water flow below 1500rpm
Matt.
Matt.
I dont think you'll have many cooling problems with the std water pump!
Anyway - CCC did a test of electric water pumps a few years back and gained 4 or 5 bhp which aint bad at all ! On a CVH I'm sure they used a cam belt from a Clio ( I think) as it was a bit shorter.
