Stupid oil question :cry:
Old Sep 21, 2004 | 01:21 PM
User 32922's Avatar
User 32922
Default Stupid oil question :cry:
what tempertaure does oil get to under normal driving conditions and how long does it take to get there?
I just connected all my Defi guages and the oil temp one didn't move from 50degrees in a 10 minute journey. Just wondering if it would take longer to heat up or if i have f***ed up the wireing
cheers
Paul
Old Sep 21, 2004 | 05:25 PM
MarkRS2k's Avatar
MarkRS2k
You'll need longer than 10 minutes to get it warm, depends on the temperature outside, will take about 10 MILES until the oil is at 70-80 degrees, this is when you can safely rag it, ragging before damages your engine nicely
Old Sep 21, 2004 | 06:14 PM
SPADGE's Avatar
SPADGE
My deffi doesn't move for about 10 mins either mate as the oil takes a while to warm-up hence not giving the car any stick for a good 5 miles or so! Normally reads around 80-90 after that
Old Sep 21, 2004 | 06:33 PM
richm's Avatar
richm
Also depends where the sensor is, which will determine if a true temperature is being measured....
Old Sep 21, 2004 | 06:37 PM
ballin's Avatar
ballin
wheres the best place then rich?
and how goods the sump?
Old Sep 21, 2004 | 06:49 PM
richm's Avatar
richm
main thing is to ensure that the sensor is exposed to oil 'flow' at a representative temperature. In the sump is fine.
Mounting the sensor, for example, in a 'dead end' fitting off the side of the crankcase oil pressure adaptor, is likely to not give a representative temperature of the bulk oil.
Old Sep 21, 2004 | 07:04 PM
Andreas's Avatar
Andreas
Takes 15min to reach 65 degrees on my 4x4.
Old Sep 21, 2004 | 07:07 PM
SPADGE's Avatar
SPADGE
Must be fookin cold there Andreas
Old Sep 21, 2004 | 07:09 PM
User 32922's Avatar
User 32922
cheers spadge
oh it did go up on the way home racing....ummmm i mean following a coupe 20VT
i thought my sensor was broken lol
cheers for the replies people
Paul
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
