FAO Rainbird re my Turbo choice.
Old Sep 21, 2004 | 12:21 PM
Ima-Racing500's Avatar
Ima-Racing500
Default FAO Rainbird re my Turbo choice.
Mike...just spoke to your mentor and yes this is the turbo non roller bearing but saw 437bhp @ 26psi on greys........that aint the limit of the turbo though apparently this was the safe injector limit before running out of fuel...so a max 450 ish from greys flat out i guess......Obviously on my spec i'd have to run more than 26psi...but Vince reckons it will hold 34psi all day so no worries So with 8 greens i wonder what it what acheive at 34psi......
People had me worried for a minute that i'd just got a T34 .63 capable of 385bhp max
Old Sep 21, 2004 | 12:23 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Told you not to worry .
What did he say the limits of the turbo were if enough fuel was supplied?
Old Sep 21, 2004 | 12:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
you gonna RR the car IMA to check?
Old Sep 21, 2004 | 12:33 PM
Ima-Racing500
He has not tried on anything other than greys as far as i could tell.He hadnt tried the 34psi held...saying i had probably got the full type monte version with the biggest wheels possible seeing as i said that 450bhp was the target....but was told that it was only a little less laggier than the T4......which to me is ok with my std comp ratio......i think i made the right choice..plus it didnt need the drop bracket for the alternator and everything just fitted straight on
Steve...yes it will be setup on the rollers to make sure everything is ok.
Old Sep 21, 2004 | 12:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Cool, jus thought as this quite an unknown turbo itd be good to get a real number from it
Old Sep 21, 2004 | 12:46 PM
Ima-Racing500
Mike...put the Dyno plot up will you on the 437BHP one???
Old Sep 21, 2004 | 12:49 PM
Mike Rainbird
Caraholic
Phil,
Go and search for it you lazy fucker . It's on one of Jim Green's posts (that he started).
I ordered the intercooler in T4 size inlet / outlets like you asked for, so you will need the drop bracket hoses .
Old Sep 21, 2004 | 12:50 PM
JAP CRAP's Avatar
JAP CRAP
and leave Harvey alone he's busy
Old Sep 21, 2004 | 12:53 PM
Ima-Racing500
Mike...say that again???....I am using T4 hoses modified...i WONT need the drop bracket as far as i can see
I cant find the plot...now prove your useless worth
Old Sep 21, 2004 | 05:20 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What turbo have you got phil?
Old Sep 21, 2004 | 05:30 PM
Ima-Racing500
T34 .63 but with a larger comp wheel and larger exhaust wheel.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
