what clutch 4 a stage3 3dr
Old Jun 1, 2007 | 06:40 PM
rstdaz's Avatar
rstdaz
Default what clutch 4 a stage3 3dr
i have a 3dr cosworth which needs a new clutch it has 330bhp so i need it to cope with the power but i dont want it to be that heavy as i use the car every day.can any 1 recommend anything
Old Jun 1, 2007 | 06:48 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Six paddle AP/Alcon plate with a new standard Ford cover will be fine
Old Jun 1, 2007 | 08:26 PM
bigad4x4's Avatar
bigad4x4
I use alcon 6 paddle clutch with h/duty cover and its fine not heavy at all
imo and feels like a standard clutch untill your in traffic
choose the alcon over the AP one due to it being easier on the legg
but as rich says both will do the job go for the alcon
Old Jun 1, 2007 | 10:30 PM
Tev's Avatar
Tev
Im runnin ap 6 paddle with standard clutch cover, its handled all the abuse ive thrown at it, in traffic its spot on no worse than a standard clutch
Old Jun 2, 2007 | 05:49 AM
Group a will be fine.
Old Jun 2, 2007 | 03:28 PM
Niall.b's Avatar
Niall.b
i fitted a Reyland hydraulic conversion which helps
Old Jun 2, 2007 | 07:40 PM
Hydraulic is so much better isn't it ??
Old Jun 2, 2007 | 10:18 PM
mechanic28's Avatar
mechanic28
i am using a standard clutch having no trouble at all
Old Jun 3, 2007 | 11:50 AM
LukeT's Avatar
LukeT
I have AP 6 paddle but i would deffo not wanna use it every day!
Old Jun 3, 2007 | 12:51 PM
Tev's Avatar
Tev
Yer from what ive been readin up on the conversion its supposed 2 b a really good mod,
It enables u 2 run a Heavy Duty Clutch, but keep most of the feelin n lightness of a standard cluth,
And 1 of the best bits is that it enables the clutch 2 full Disengage from the flywheel, so u dont get that nasty dragin when in traffic and it ultimately it pro-longs the life of ur clutch, savin u money in the longrun
Winner in my eyes shame i just couldnt afford it last time i replace my clutch
Old Jun 7, 2007 | 08:41 AM
Cawood's Avatar
Cawood
good cos im going for 380bhp n have just fitted a std clutch
hope it holds out, although it is one of the older ones which AP used to make
Old Jun 7, 2007 | 12:42 PM
dazzle740's Avatar
dazzle740
i use a alcon 6 paddle spinner plate with a ford motorsport cover and bearing, light as a standard clutch with the bite of a 6 paddle.
By the way mine is running 380 (ish)
Old Jun 7, 2007 | 03:25 PM
DAN P's Avatar
DAN P
ap 6 padle standerd cover my std clutch did not last with 280 bhp
Old Jun 7, 2007 | 04:14 PM
ricky_3dr's Avatar
ricky_3dr
AP/Alcon 6 paddle with heavy duty cover for longevity
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
