Soft cut limiter on ERST
Old Sep 21, 2004 | 09:01 AM
Oranoco's Avatar
Oranoco
Default Soft cut limiter on ERST
After my sedate drive home last night I noticed ( a couple of times) how harshly the rev limiter is on teh RS Turbo. When I used to thrash the pants off the old XR it used to bounce nicely off the limiter.
I wondering whether it would be possible to put a soft cut limiter on and how much agro it would be. Oh and whether I'd gain any/much benefit from doing so?
Old Sep 21, 2004 | 09:03 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Not too much agro TBH. You need to remove the factory limiter, then install an aftermarket limiter from someone like Omex. This will allow either a Hard or Soft cut.
Old Sep 21, 2004 | 09:10 AM
Tim's Avatar
Tim
As christian says the omex 1 is very good had this on my old car with the rpm limit removed from the fuel and boost ecu's.
Old Sep 21, 2004 | 09:16 AM
Oranoco's Avatar
Oranoco
How do you go about removing the limiter from the other ECU's?
Is this what I was hearing about changing the value of the capacitors value?
Old Sep 21, 2004 | 09:19 AM
Tim's Avatar
Tim
Yes sort of, 1 has fuel cut 1 has spark cut Karl can help you he did all mine dunno anyone else.
Tim
Old Sep 21, 2004 | 09:23 AM
Oranoco's Avatar
Oranoco
Cheers Tim. Another job added to my to do list over winter
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
