car feels like it has a rev limiter when it hits boost
Old May 30, 2007 | 06:46 PM
pig's Avatar
pig
Default car feels like it has a rev limiter when it hits boost
im having trouble with the motor(mk2 escort cossie)when it comes up on a bit of boost it seems to hit like a limiter then or back fire's slighty.i replaced the 3-bar map sensor today but still the same,new plugs as well.pissing me off now was wondering if any of you guys could sheed a little light on it and guide me a little please.
cheers paul
Old May 30, 2007 | 08:47 PM
pig's Avatar
pig
help up
Old May 30, 2007 | 09:19 PM
Overboost
Old May 30, 2007 | 09:35 PM
DROPTOP's Avatar
DROPTOP
boost limit on ecu?
Old May 30, 2007 | 10:02 PM
pig's Avatar
pig
cheers guys ,but how do i go about looking to sort the faults out,is there any thing i can look at or test on my own over these possible problems?
cheers paul
Old May 30, 2007 | 10:13 PM
DROPTOP's Avatar
DROPTOP
what boost are you running? drop the boost bit by bit and see if it stops cutting out.
Old May 30, 2007 | 10:33 PM
pig's Avatar
pig
i tryed that pryer to fitting a new map sensor to no avail,i will try it again tomorrow tho now the new item is on.its running about 28 psi at present bud
Old May 31, 2007 | 06:46 PM
DROPTOP's Avatar
DROPTOP
this forums fucking wank! all these cossie owners leave someone whos never even been in one to try and advise .
does the ecu cut if the acts get too high?
has it got a knock sensor? timing could be miles out?
air leak?
Old May 31, 2007 | 07:33 PM
pig's Avatar
pig
cheers fella,i thought this was THE place for cossie info and advice.so i thank you for your time m8.am putting a new crank sensor,temp sensor and air sensor(think thats what it is) on tomorrow and will try this next.
thanks again m8 for yoyur reply ,timing is spot on i will look as well tomorrow for any air leaks as well
Old May 31, 2007 | 07:41 PM
DROPTOP's Avatar
DROPTOP
it is the place normally . must be rag week or something
Old May 31, 2007 | 08:13 PM
What plug gaps are you running ?, have you got a group a coil ?
Don't go wasting your money just replacing stuff, all those you list will not cause this.
Old Jun 1, 2007 | 12:03 AM
pig's Avatar
pig
think the gaps are .5mm and yes it is running a group a coil
Old Jun 1, 2007 | 08:25 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Had a similar problem with mine, turned out to be a dodgy plug, the ceramic body had a hairline crack in it, replacing it cured it for good.
Old Jun 2, 2007 | 01:21 PM
pig's Avatar
pig
thank you very much to the few people that replyed to my question.the car is now sorted and running fine.it turns out that it was the crank sensor.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jay030787
Aug 17, 2015 06:16 PM
fatboy billy
Aug 3, 2015 08:34 AM
sjssms
Aug 2, 2015 07:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
