xr3i cab wont lock? help needed please
Old May 30, 2007 | 05:18 PM
tacha's Avatar
tacha
Default xr3i cab wont lock? help needed please
hey guys ive temporarily got a mk 4 xr3i cabriolet but the doors wont lock with the key.
the central locking works on the switch on the inner door handle but thats useless coz i need the car to lock when im not in it.
any advice would be appreciated.
Old May 30, 2007 | 05:20 PM
RS 5tu's Avatar
RS 5tu
will you key lock the door?
maybe dodgie lock i have mk4 cab andmy drivers side wont lock.
Try WD40 has worked in the past on my mk3 cab..
Old May 30, 2007 | 05:27 PM
tacha's Avatar
tacha
the doors wont lock at all using the key from the outside. neither driver or passenger.
in the politest way possible where do i stick the wd40
Old May 30, 2007 | 05:29 PM
RS 5tu's Avatar
RS 5tu
in the lock hole where u put you key seriously i worked for me.
Old May 30, 2007 | 05:33 PM
tacha's Avatar
tacha
thanks hun ill give it a try
Old May 30, 2007 | 06:19 PM
If the key is rotating fully to the lock position then it is going to need the door panel off to see what is what.
Has it ever worked from the key either side ?
I found on my cos someone (previous owner) had disconnected the short rod that goes from the key barrel to the lock mechanism itself, both sides, so I did not need the Ł10 worth of door locks I bought, should have looked first!!
I think they do this to help stop theft.
Old May 30, 2007 | 06:36 PM
tacha's Avatar
tacha
thats exactly what its doing, normally you can feel a catch but u cant its just rotating.
will take it apart tomorrow and see whats going on
if it is that i owe you big time
Old May 30, 2007 | 11:45 PM
SafeChav's Avatar
SafeChav
Thats odd, on a MK4 the doors should lock with ANY key
So if they key doesnt operate the lock, your barrels are probably knackered
Old May 31, 2007 | 03:03 PM
tacha's Avatar
tacha
yep as said the barrels were buggered.
tony loaned me the drivers side barrle of the xr2i and it works a treat
thanks for all your suggestions
Old May 31, 2007 | 03:14 PM
SafeChav's Avatar
SafeChav
I think the full lock sets are still available for Mk4's at Ford, its nice to have everything on one key aswell
JoeyBoyden
Jan 4, 2024 02:36 PM
carlo
24
Oct 5, 2015 08:20 PM
Dahl88
Aug 22, 2015 08:16 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
col93saphcos
Aug 7, 2015 03:21 PM
