whos knows there stuff when it comes to chips??
i have this chip and its ofab frst
i am currently using ofac with a 15psi superchip fitted
what i would like to do is move on to my other ofab management and use the pictured chip but im told its no good if its got no tape over the magic eye
is that true and where can i get it remapped??
cheers peeps
any help is very apreciated
if this sounds pointless then pls say but i figure im at 15psi now and would like to run more when i transplant the runnin gear out of my rst and into my mk1 xr2
cheers peeps
fingers x'd then
i shud be drivin but dvla has stole my licence
soon as i get it back i can test the car with both to see whats best i guess
if the fab cuts at 10psi then ill just have to send it odd for a remap
do they do a off the shelf type of map??
engine is pretty much std
285 cam
filter
stainless
hybrid
nowt special
285 cam
filter
stainless
hybrid
nowt special
PassionFords Creator
The OFAB & C are non interchangeable and will reguire new programming. The problem is the programming code is going to be unknown as that is NOT a Superchip for starters...
The window is there so we can bathe it ultraviolet light to erase its contents, so just pop any old sticker over it for protection.
i have 2 sets of frst management
the chip is the ofab(rest in in ther shed)
car is currently running ofac on a superchip (fitted to the car)
i know the pictured chip is not superchip
this 1 on left is
i would guess its been erased by now, ill put sumthin over it neways just incase
would you be able to reprog the chip??
this 1 on left is
No, Im afraid i only reprogram my own modules, which are the modern ones that are 1/2 the size and less than 1/2 the weight of those pictured.
