Iridium vs. platinium plugs
Old May 30, 2007 | 12:25 PM
Azrael's Avatar
Azrael
Default Iridium vs. platinium plugs
I recently got asked boout the difference in aplications and good and bad points of both and I found out I don't know and I can't simply find anyting apart form marketing bable. Maybe someone will know here?
Old May 30, 2007 | 06:41 PM
Mark Shead's Avatar
Mark Shead
I run the iridium plugs in everything from stock cars to Rods engine on all the topspeed runs and I like them and have never had a problem with them,
I have not tested them back to back with other makes so I cant tell you the diff only I like them , If I get chance to try a diff type of plug on the dyno I will try and see if any make any diff.
Some people hate the Iridium plugs as they blame them for breaking engines but I have not found this to be true and I have run these plugs hard .
Mark
Old May 31, 2007 | 11:15 PM
Azrael's Avatar
Azrael
Mark Shead thx for input
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
