Hows this carb turbo set-up work? and why...
Old May 28, 2007 | 08:44 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Hows this carb turbo set-up work? and why...
Sucked through turbo compressor and blown straight into the inlet?
Benefits?
Why?
Dangerous?
If you run an intercooler, would you need to run more petrol through the carb?
Chances of it running lean?
Old May 28, 2007 | 10:01 PM
Charlie Chalk
Unknown.
knock knock
AlexF's Avatar
AlexF
I told you on msn
Old May 28, 2007 | 10:02 PM
Charlie Chalk
Unknown.
that dont answer my questions...
Old May 28, 2007 | 10:03 PM
mechanic28's Avatar
mechanic28
wot boost is it?it abit dangerous really on a petrol engines due to the charged air temperture
Old May 28, 2007 | 10:06 PM
Mark V8's Avatar
Mark V8
DON'T DO IT
Very old skool set up, no chance at all of running an intercooler as any backfire in the inlet will cause it to explode
Mark
Old May 28, 2007 | 10:18 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Common enough on old turbo setups.
Renault 5 Gordini Turbos were like that, as were a few other early turbo cars.
Lots of the early Rover V8 turbo conversions were like it.
Cant run an intercooler, but the charge temps are massivley lower than usual, as the fuel does the cooling.
Wears turbo out faster tho too, both the blades and the seals, tho there are turbos specially made for this purpose.
Overall though not really reccomended.
Old May 28, 2007 | 10:33 PM
Fast Guy's Avatar
Fast Guy
Not that dangerous on the low boost like they run, I think it was only something like 5-6psi, but if you start upping the boost then expect problems.
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
cameron2
Aug 10, 2015 12:14 PM
mick pearson
Aug 9, 2015 09:19 AM
