"fuel low" light blinking - anyone got an idea?
Hi folks!
Anyone got an idea what could cause the "fuel low"-light to blink?
It blinks for about 20sec, then stays dark and does not come on even if the fuel-tank is empty
maybe some kind of error code or just a sign that the connection to the sensor is not ok?
what do you think?
what do you think?
Yeah chap, sounds like a failed connection to the sender.....all the level displays work the same way, disconnect the washer fluid bottle and the warning lamp will copy that of your fuel level lamp.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
