steering wheel boss
Old May 28, 2007 | 02:29 PM
ossie cossie's Avatar
ossie cossie
Default steering wheel boss
will a standard mk5 escort steering wheel boss fit a big turbo escort rs cosworth? if not what other model will?
Old May 28, 2007 | 02:51 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
G day
a escort mk5 standard one won't fit as a escort cosworth uses a sierra
type one,you will find a sierra s/wheel and a escort cosworth s/wheel
will fit each other exept for airbag model cosworths
Old May 28, 2007 | 03:19 PM
TONY F's Avatar
TONY F
think all mk 5 steering wheels should fit also i think the feza mk3 is the same boss as well, a sierra boss is not the same though
Old May 28, 2007 | 09:32 PM
THE RADMAN's Avatar
THE RADMAN
has it got an airbag? if not then it should be fine
Old May 28, 2007 | 09:42 PM
Azrael's Avatar
Azrael
What about airbag model? On mine Sabelt boss does not quite fit.
Old May 28, 2007 | 10:27 PM
The DIVA's Avatar
The DIVA
All Mk5`s without airbag are the same,including Escos....
Sierra is totally different and will not fit....
Old May 28, 2007 | 10:32 PM
Azrael's Avatar
Azrael
The Diva mine had airbag...
Old May 28, 2007 | 11:06 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i have put sierra cosworth s/wheels on mk4 escort rs turbos
have put mk4 escort rsturbo 4 spoke rs s/wheel on sierra cosworth
also put a sierra cosworth 4 spoke on a bt escort cosworth
and i know maxcos put a sierra type 4spoke rs s/wheel on a airbag escort cos and it did not fit
i tried a standard escort one on my car as a stopgap and it wouldn't
go on maybe i'll try again
Old May 28, 2007 | 11:35 PM
The DIVA's Avatar
The DIVA
Jakub.......you need a non airbag column from a big turbo car,then you can get a large range of steering wheels to fit...
Old May 29, 2007 | 06:46 AM
Azrael's Avatar
Azrael
The Diva please don't tell me that. I live in Poland. There are like 3 Cossies around, there aren't scrappies with parts for them here.
If need be I will make some boss fit.
Old May 29, 2007 | 09:01 AM
Mr.Ford's Avatar
Mr.Ford
And with airbag??
I've bought an MINT leather airbag steeringwheel from an 1996 Escort GTi. But it looks to me if it won't fit in my 1995 EsCos.
Old May 29, 2007 | 09:20 AM
ossie cossie
ok will a mk 4 escort steering boss fit up to 1990 or a scorpio boss. i live in OZ and there is one for sale on our e bay but i dont want to get it if it wont fit it says escort / orion to 1990 and scorpio. its for mt car big turbo non air bag.
Old May 29, 2007 | 09:50 AM
The DIVA's Avatar
The DIVA
Mk4 Escort will deffo not fit your car mate,Mk4 is similar to sapphire cossie but will not go near Escos....
Old May 29, 2007 | 10:02 AM
The DIVA's Avatar
The DIVA
Ok......Here`s a pic...
The boss on the steering wheel is Mk5/Escos non airbag(notice the external steering lock teeth).....the boss at the top middle is Mk4 escort(With raised bit on edge for indicator cancelling) and the boss to the left is Sapphire cossie(Similar to Mk4 but without raised bit,and has a cutout internally for indicator cancelling)
Hope this helps.....
Old May 29, 2007 | 11:53 AM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
[quote="Mr.Ford"]
You 2 get it sorted then, swap columbs then you can both be happy ever after
Dan
Old May 29, 2007 | 11:58 AM
THE RADMAN's Avatar
THE RADMAN
ill post a pic later of all the bits you need to convert from air bag to non airbag
Old May 29, 2007 | 12:44 PM
Mr.Ford's Avatar
Mr.Ford
[quote="SillyFezzaMk1"]
Dan
Only for replacing my good leather steering wheel, for a MINT example ???
I don't think so
Old May 29, 2007 | 03:59 PM
THE RADMAN's Avatar
THE RADMAN
this is everything reqd to convert air bag to non airbag,you just need the boss and the s/wheel of your choice,and to remove the airbag light from dash you also still keep a steering wheel lock doing it this way,just happens to be for sale as well
Old May 29, 2007 | 04:16 PM
SillyFezzaMk1
Rubber Rhino Crew
lol tru tru, bit extreme......in a few yrs maybe when mint Swheels will be like rocking horse.
Dan
Old May 29, 2007 | 06:21 PM
Azrael's Avatar
Azrael
THE RADMAN you got PM
Old May 29, 2007 | 07:33 PM
THE RADMAN's Avatar
THE RADMAN
so have you
Old May 30, 2007 | 12:22 AM
ossie cossie
thank you THE DIVA all clear now i have seen a photo to compare them all.
pabloXR
Sep 21, 2015 12:42 PM
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
