whats the differents between l6 l8 ecu's
Old Sep 20, 2004 | 07:55 PM
escort1989uk's Avatar
escort1989uk
Default whats the differents between l6 l8 ecu's
is one 2wd and the other 4wd or can these to be swap between them on a 2wd loom
Old Sep 20, 2004 | 07:56 PM
Rhys's Avatar
Rhys
iones called L6 and the other L8
other than that im not sure mate sorry
Old Sep 20, 2004 | 08:13 PM
ECU Monitor Enthusiast
The level 8 has a knock sensor input and a narrow band lambda sensor input plus
has exactly twice the amount of memory as the Level 6 otherwise it is
the same !
The software (CHIPS) between these ECU's are NOT compatiable !
Old Sep 20, 2004 | 08:36 PM
Billabong's Avatar
Billabong
2wd loom also requires the outer two wires on the TPS plug swapping in conjunction with fitting a PF09 4x4 TPS if using the L8. Not all L8's were lambda enabled.
Old Sep 20, 2004 | 08:40 PM
Just to clarify this point Bong,
The lambda function/knock function on a Level 8 is dependant on the software in the chip only.
ALL level 8's had the extra hardware to read the Lambda sensor and knock inputs.
Old Sep 20, 2004 | 08:43 PM
Billabong's Avatar
Billabong
My bad, thanks for clearing that up (so, not all L8 are lambda enabled as I said, but you can enable them to run lambda )
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
liamT74
Sep 23, 2015 10:24 PM
