Mobile auto electrican needed
Old May 26, 2007 | 07:22 PM
Default Mobile auto electrican needed
Does anyone know of any good auto electrican's in middlesex/west london
need a mobile diagnostics for a 2003 renault clio
it's a non start relating to the imobiliser
Old May 27, 2007 | 10:48 AM
come on peep's 12 views and no replys
Old May 27, 2007 | 11:13 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Whats the problem you tart?
Old May 27, 2007 | 11:14 AM
It wont flippin start
immobiliser red light stays on all the time
checked all fuses and relays and no go still
Old May 27, 2007 | 02:04 PM
SafeChav's Avatar
SafeChav
Jesus christ how many time do i have to tell you man
TAKE IT TO RENAULT
Old May 27, 2007 | 04:36 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
just get a reader ring mate nine odd quid from reno fit bucket loads of them goes rnd ignition barrel failing that it will be the key dropped its code and reno are the only pple that can recode. but for 9 quid get on it
Old May 27, 2007 | 04:37 PM
NEEDFORSPEED
theres also 3 small relays under bonnet that cause problems pull em out n swap around but not if led is defo staying on
Old May 27, 2007 | 05:41 PM
TAKE IT TO RENAULT
I know andy
just dont want to go bankrupt if it's an easy fix i dont know about
NEEDFORSPEED
Are the ring's easy to fit ?
dont think the key has dropped the code as the central locking still works
Had the plip batterys changed friday so it isnt them
thnx for the replys peeps
Old May 27, 2007 | 05:44 PM
allready had them out before
dont know where to get a new one to try that route
but as you say if the red lights constant it might not be them
Edited to say
it has started today just not first time
owt to do with it raining
i know the mk1's had water ingrese problems
Old May 27, 2007 | 06:00 PM
SafeChav's Avatar
SafeChav
I doubt you'll go bankrupt, can't see it being more than an hours labour really.
Surely gota be worth considering all the ball ache you are having
Old May 27, 2007 | 06:05 PM
Will have to phone them up tuesday to book a slot then
Old May 27, 2007 | 06:28 PM
NEEDFORSPEED
if it started but not first time i doubt its the immob cos its either on or off, yeah have a few problem with water, had a few broken wires in the loom from ecu downwards and also the black metal box just behind the engine rubbing through the loom (it covers some plugs up) reader ring just clips on
Old May 27, 2007 | 06:38 PM
I tried getting the black cover off the ecu yesterday with no joy
ye some time's the imobiliser will go off and let the glow plugs come on
other time's not like last night
Will have to try GSF first for a barrel ring before phoning renault
Old May 29, 2007 | 02:55 PM
NEEDFORSPEED
Just been quoted £44 for a Anti-theft ring from renault west london
So i dont know where uve got ur's from
mk22door
49
Mar 26, 2022 07:15 AM
JPA
Nov 8, 2015 12:26 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
