blowing off the rocker cap???
Old May 26, 2007 | 06:40 PM
Fiestamatt's Avatar
Fiestamatt
Default blowing off the rocker cap???
can any1 shed any light on why i keep blowing off my oil filler cap, what could be wrong, how can i fix it.
Thanks in advance
Matt
Old May 26, 2007 | 07:18 PM
jrs's Avatar
jrs
It could be crankcase compression (worn rings) but as you have a new engine try a new cap the rubber seal go's in the inside try the new type with the grub screw
Old May 27, 2007 | 08:39 AM
Oranoco's Avatar
Oranoco
Strip and clean out your breather system before worrying about serious issues. And buy a NEW oil cap as the rubber seals in them go shitty after a time.
Could also be ring blow by pressurising the crankcase, but do the above first before worrying about that.
Old May 27, 2007 | 11:23 AM
turboben's Avatar
turboben
have you got a chrome rocker cover as i found when i fiited mine the cap kept blowing off when i put the standard one back on it was fine
Old May 27, 2007 | 12:18 PM
Fiestamatt's Avatar
Fiestamatt
ill give the above a try, thanks for your help peeps.
Matt
Old May 27, 2007 | 08:44 PM
ram's Avatar
ram
Has a large member
mine kept blowing off. since ive changed the head gasket and put a new cap on it doesnt happen. but theres still pressure quite abit of pressure in the head. not sure if thats normal or not?
Old May 31, 2007 | 01:52 PM
Mr Sam's Avatar
Mr Sam
engine cant breath somewhere
Old Jun 1, 2007 | 04:44 PM
ram's Avatar
ram
Has a large member
Old Jul 8, 2007 | 10:40 AM
beef2001's Avatar
beef2001
Boost it
yeah mine get coming off but then i put it over the rubber tight fit no probs
Old Jul 8, 2007 | 12:06 PM
Mr Shannon's Avatar
Mr Shannon
Get a rocker cover with a screw on cap instead
Old Jul 8, 2007 | 05:25 PM
jrs's Avatar
jrs
Think he was looking for the reason why it's doing it Don't think he was looking for a solution
Old Jul 8, 2007 | 06:55 PM
Oranoco's Avatar
Oranoco
And a poor fudging solution at that. Sort the problem not the symptom
Old Jul 8, 2007 | 09:58 PM
beef2001's Avatar
beef2001
Boost it
Wat thats all a bit too technical I gave advice that will stop the cap from coming off
Old Aug 22, 2007 | 11:50 AM
fizzyturbo's Avatar
fizzyturbo
have a look at the breater pipe at the back of the block, its usually to do with a bit of crank case pressure, or maybe think about a breather system, tend to work better then the stock ford system
Old Aug 22, 2007 | 12:08 PM
jayRS's Avatar
jayRS
take the breather filer/pot off and replace it, your problem will be there more than likly.
but dont bin the old one, i may want it
Old Aug 25, 2007 | 10:41 PM
BRAMMER's Avatar
BRAMMER
Did you get sorted matt???
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
20/20 vision
Sep 28, 2015 03:03 PM
SMILER258
Sep 28, 2015 09:04 AM
