HOLDING BOOST ON T3
Old May 26, 2007 | 01:01 PM
m_nettleship's Avatar
m_nettleship
Default HOLDING BOOST ON T3
Can you hold 24psi on a t3???????
Old May 26, 2007 | 04:14 PM
Would not have thought so, anyone else ?
Old May 26, 2007 | 04:40 PM
cossie604's Avatar
cossie604
You can but it wont last very long...also your charge temps would be quite high at that level due to the small turbo having to work its bollocks off imo
Old May 26, 2007 | 08:15 PM
col cos1's Avatar
col cos1
i ran greens stage 3 etc on 18psi with no probs,wouldnt of fancied as much as 24 to be honest
Old May 27, 2007 | 08:23 AM
m_nettleship
Well its running a front mount with 60 m core. in 5th it peaks at 26 and keeps droopingoff to aabout 19psi. all the breather system, etc. It running about 390 torque, and 330bhp.
Old May 27, 2007 | 09:38 AM
Carlsworth's Avatar
Carlsworth
Former Sponsor
a t3 with 360 thrust bearing and a decent actuator would hold 24 no probs
cossie604's Avatar
cossie604
Make sure you give that turbo a decent send off when he die's then
Old May 27, 2007 | 10:09 AM
Twellsie's Avatar
Twellsie
mine peaks at 25 psi then holds 20 psi with no probs
Old May 27, 2007 | 11:26 AM
mechanic28's Avatar
mechanic28
when i had my T3 turbo on not so long ago,would not hold above 21psi !had to move up to a T34 holds 23psi all day long now
Old May 28, 2007 | 11:01 AM
m_nettleship
I carnt see a t3 holdin 24psi, just seen one of them stainless steel manifolds, 200 qid, anyone used them????
mechanic28 does it spit flames with no afterburner kit?????
Old May 28, 2007 | 12:15 PM
mechanic28's Avatar
mechanic28
sometimes it spits out flames,but have a flamer kit as well,bloody wish i did not bother with it now,one of those spur of the moment things if i was u i would get a T34 with .48 exhaust housing which will cut down the lag and can handle stage 3 boost lebels no probs!although still will reguire a remap!
Old May 30, 2007 | 09:56 AM
cossie boy8's Avatar
cossie boy8
my old t3 used to peak at 24psi and hold 22psi
as said though it didn't last very long and when i took it off it had 5 or six cracks inside the exhaust housing!
Old May 31, 2007 | 09:19 PM
m_nettleship
Well bin oiut in moter today, just got bk in, and on over run am getting thick blue smoke, when u press the throttle bk down??????????Gutted now. Any ideas
Old Jun 2, 2007 | 12:05 AM
BigErn's Avatar
BigErn
My T3 used to peak 24psi and drop off to 16psi.
Now my T34 peaks 24psi and holds 20psi but on a ported and polished head its working the greens too hard and leans off up the revs.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
