Driveshaft Torx Bolts
Old May 25, 2007 | 10:57 PM
marleysdad's Avatar
marleysdad
Default Driveshaft Torx Bolts
Hi all, any ideas on how to remove some rusted, rounded off torx bolts that hold on the rear driveshaft flanges on Escort Cossie (both inner and outer sides?)
Old May 25, 2007 | 11:44 PM
THE RADMAN's Avatar
THE RADMAN
you could drill the heads off,might have to remove the rear hub to enable the shaft to pull off over the bolts,then just unscrew the remaining bolts from the flanges
Old May 26, 2007 | 02:50 AM
dave green's Avatar
dave green
Heat them up, then a good pair of mole grips, all ways works for me.
Dave
Old May 26, 2007 | 04:20 PM
Probably easier to grind heads off then replace with CAP heads + COPPASLIP on threads!!
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
