thick question about a 3 pin switch on/off
ok bought a switch for my anti lag and it has a light on it.
it has 3 pins
A
Earth
ok well with anti lag you need to put one wire in from ecu pin and needs to be switched to earth
on of these pins is for light on switch which one?
it has 3 pins
A
Earth
the light will become illuminated when the switch is in the on position, but since your switching the neg not the poss im not sure you could wire it to light the lamp unless you also used a small relay.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
rsguy
44
Sep 29, 2015 03:29 PM
