missfire problem
Old May 24, 2007 | 03:45 PM
ceri.demarco's Avatar
ceri.demarco
Default missfire problem
january 93 escort cosworth when the car warms up and you go over half a throttle the car starts missing and back fires realy bad exspecialy in first gear any help appreciated
Old May 24, 2007 | 04:04 PM
Check your gaps, plugs,phase,CPS first then look carefully at leads or just get a decent set if not already.
Old May 24, 2007 | 05:01 PM
ceri.demarco
hi would you know the gap size and can you tell me what you mean by phase and cps thanks
Old May 24, 2007 | 05:16 PM
I would run 0.6mm plug gaps.
PHASE sensor gap is 0.2-0.3mm in dizzy, Crank position sensor gap is 0.6-1.0mm.
ps Iam not overly familiar with the escys but if 93 is that FORD EEC or is it Weber ?
Old May 24, 2007 | 09:00 PM
ceri.demarco
i disconnected the amal valve and it has stopped back fireing but it is still missing badley performance of car has dropped power and now and again on tickover you rev the car and it blows out a little blue smoke
also could you please put feeler gauge sizes into inch for me
thank you
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
