Apexi AVC R Boost Controller - who to set it up
I have an Apexi AVC R boost controller on my S1.
Who can set it up properly?
Doesn't need to be a Ford Tuner
Car is an S1 and has already been mapped on a dyno.
Many thanks
Many thanks
Why do you need anyone to do it? Has it not been set-up atall? What was it mapped with? Or was it mapped on an engine Dyno?
Thing is, the AVC-R is a complicated little fella, as I told you originally and really a tuner will just get it to a basic setting in most cases, then you will fettle it over the longer term.
IMO, you can do it yourself. PM me if you need a hand.......
It hasn't been setup at all as the engine was mapped on the dyno without it.
Yes they are complicated little fella's
Been advised to go for air injectors but I like to be different. Seem to be so many advantages having a boost controller over air injectors.
Hell if it's good enough for the Jap boys and people doing top speed runs over 160 odd mph then it's good enough for me
Escortdriver1
Nov 1, 2015 07:55 PM
gchristophi
Aug 31, 2015 10:36 PM
Escortdriver1
Jul 31, 2015 02:36 PM
