4x4 saff to 2wd conversion- a few Questions.!
Old May 24, 2007 | 12:40 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default 4x4 saff to 2wd conversion- a few Questions.!
Is there an off the shelf gearbox mount avaliable to fit a T5 box into a late K plate 4x4 cossie shell?
Will a 7.5" 2wd diff fit a 4x4 rear beam?
ta
Old May 24, 2007 | 01:08 AM
david's Avatar
david
Will you have PM ref the mount but the Diva is to thank as he passed the info onto me.
As far as I know the 4x4 beam wont take a 7.5" diff.
Old May 24, 2007 | 01:16 AM
RWD_cossie_wil
cheers mate you are a star
Old May 24, 2007 | 05:48 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i looked into this a while back and to do the job right it was going to cost about £1200....and that's second hand parts......but u can then sell/part ex ur 4x4 stuff and make ur money back..........
Old May 24, 2007 | 09:58 AM
RWD_cossie_wil
I have all the bits already, and the conversion is done , but I want a better mount for the 2wd box as the car is running 450ish+, and I have had to fabricate a mount using box section steel which is ok, but idealy want somthing thats made for the job to tidy it up
And I am just wondering if I can avoid having to swap rear beams but it looks like I will be having a few days under the car , as I don't think a poor little 7" diff is going to take 38psi of T4 abuse for too long
Old May 24, 2007 | 02:35 PM
RWD_cossie_wil
up
Old May 24, 2007 | 02:37 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
38 psi on a t4 that must feel awesome
Old May 24, 2007 | 02:59 PM
pete mcrash
..........would feel better in a 4by..........
Old May 24, 2007 | 05:08 PM
RWD_cossie_wil
nah 4x4 is sloooooooooooooooooooooooow
Old May 24, 2007 | 05:21 PM
pete mcrash
.....shut up u tart......when u've stopped spinning then u might catch me..........if its dry.............
Old May 24, 2007 | 05:39 PM
RWD_cossie_wil
.....shut up u tart......when u've stopped spinning then u might catch my gearbox as it flies out the back of my car..........if its dry.............
Old May 24, 2007 | 06:05 PM
charlie luciano's Avatar
charlie luciano
why bother with all that fookin around just go and buy a 2wd
Luciano
Old May 24, 2007 | 06:14 PM
pete mcrash
..........ohh so true..........3 box's in 5000 mile...
Old May 24, 2007 | 09:06 PM
RWD_cossie_wil
Luciano
The car is absolutly mint, is silver, got mint leather, full chrome bay, 500ish BHP ( 38psi on a T4 ), is aeroquipped, 18" comps, and all the dizzyless/ coilpacks/ Closed loop/ 1000cc injectors MSD live mapped etc, and a full service history, and I have know the car for two years, and I can't be fucked spending months and months looking for a 2wd that still won't be anywhere near as nice a car unless its going to be 15-20k . And I have a doner 2wd car sat waiting.
4x4 is ok, but I already have an escos that the drivetrain is costing 5kish to sort, and it STILL won't be as strong as a good old T5
next question?
Old Jul 1, 2007 | 04:46 PM
mattajturners's Avatar
mattajturners
did you have any joy with the gearbox mount?
i have just converted a 4x4 to 2wd and have come unstuck, i dont have a mount.
what do i need?
Old Jul 1, 2007 | 04:58 PM
CozzyBrom's Avatar
CozzyBrom
why do you want a uprated gearbox mount ?
all the gearbox mount does on 2wd is hold the gearbox level in the tunnel
you gonna need to take beam out if you have an adjustable one anyway
Old Jul 1, 2007 | 05:06 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I'll let you know Rich when Will throws me the keys
Old Jul 1, 2007 | 05:23 PM
mattajturners
is there a std mount i can use?
Old Jul 1, 2007 | 07:12 PM
RWD_cossie_wil
Not an uprated mount brom, the actual mounting bracket on the bottom of the gearbox that links the rubber mount to the tunnel. Obviously the 4x4 and 2wd std gearbox mounting brackets won't line up a T5 in a 4x4 shell, so for the time being just to get the car rolling and driving ( very gently) , I have had to put a bit of box section steel inbetween the 2wd mount and the 4x4 chassis pick ups,.which works but I can't see it coping well with the power, so I want a decent mount that fits properly, hopefully the part I have from ford will do the job as it is meant to fit a T5 into a 4x4 shell
On a seperate note, if I give you a 4x4 rear beam to do your conversion on, is it a pain in the arse to make it take a 7.5" diff, or is it easier to give you a 2wd one?
Old Jul 1, 2007 | 07:21 PM
The DIVA's Avatar
The DIVA
Yes........I will pm you a finis code....
Old Jul 1, 2007 | 07:34 PM
RWD_cossie_wil
already done Diva . how far is your escos along mate?
Old Jul 1, 2007 | 07:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default Re: 4x4 saff to 2wd conversion- a few Questions.!
i'm sure there is
the 4wd shell was used in a lot of later spec sierras (wider tunnel and extra holes for the 4wd mounts) so it should fit up ok
yes, with a bit of adjustment you can make it fit
you just have to lop off a bit of the top of the diff where the bolt goes through
or
widen the beam a little
easier to lop the bolt bit off
Old Jul 1, 2007 | 07:45 PM
CozzyBrom's Avatar
CozzyBrom
the have spacers as standard on the gearbox mount anyway
i will mod your beam you tight cooont !!!!!!!
Old Jul 1, 2007 | 07:55 PM
RWD_cossie_wil
ok, so if I put a 2wd diff into the 4x4 beam on the escos, will 2wd drive shafts bolt onto the 4x4 stub shafts? Also, I have a 2wd beam on a different car, would it just be easier to give you that and the trailing arms to mod for my escort?
Old Jul 1, 2007 | 08:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as brom says, no need to change the gearbox mount from your box section really, as it doesn't do much. the engine mounts take the torque as they are much further away from the centre of rotation
but if there's one off the shelf that's cheap enough, then may as well do it
why keep the part number to pm though? don't we share knowledge on this site? isn't that the founding principle behind it? a reference site for ford enthusiasts it says at the top of the page
Old Jul 1, 2007 | 09:00 PM
RWD_cossie_wil
Well the finis code for the gearbox mount is 6177696 , And it costs a mighty £12 , so better to have the propper job and be sure the prop angle is correct and fits as factory, as a bit of box section steel looks a bit pikey IMHO, and my gearbox just touches the tunnel at the moment as I had to make mine there and then as my car was blocking my mates ramps up
And at £12 it might as well be done %100 perfect
Old Jul 1, 2007 | 09:06 PM
foreigneRS's Avatar
foreigneRS
Testing the future
RWD_cossie_wil good man
Old Jul 1, 2007 | 10:12 PM
abdr500's Avatar
abdr500
i have this mount in my car i think its one off the sierra s you will need to cut a littel hole in the side of the mounting braket for the speedo cable to fit through other wise it will be on a bad angel cable wount last long be ther done it
Old Jul 1, 2007 | 10:15 PM
RWD_cossie_wil
yep, thought that might be the case ABDR
Silly question mate, but have you ever been in the RAF? , as ABDR stands for aircraft battle damage repair
Old Jul 1, 2007 | 10:18 PM
abdr500's Avatar
abdr500
no been involved with many other things
Old Jul 1, 2007 | 10:20 PM
c0ss1e9i6's Avatar
c0ss1e9i6
Franco
ta
It would be cheaper to get a nail of a 2wd and do it up!
Keep the 4x4 for shit weather! We get enough of it!
Old Jul 1, 2007 | 10:24 PM
abdr500's Avatar
abdr500
c0ss1e9i6
shit weather and 2wd ==== lots of fun and not alot breaking
Old Jul 1, 2007 | 10:29 PM
RWD_cossie_wil
read them above posts cossie 916 i have the doner car sat next to it , 4x4 is wank , I can't afford 2x 4k drivetrains, one is enough , and besides, RWD is the best fun you can have in a car with your cloths on and the conversion is already done %95
What else you been involved in ABDR? and whats your name anyway?
Old Jul 1, 2007 | 10:31 PM
c0ss1e9i6's Avatar
c0ss1e9i6
Franco
Bigger top end too!
Still fookin dangerous on britains roads with the right power!
(and sorry I didn't read all the above!! )
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
rog
Sep 16, 2015 03:00 PM
tib2220
Sep 14, 2015 12:33 PM
